Opcua
Добрый день. Контроллер 6.8.2B/1G 527 sn AGRJZZR2 wb-2304 ( на тестовой тоже пробовал).
Настроил Шлюз MQTT-OPC UA но при подключении некоторые значения получаю ошибку:
ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L2-L3Q’
Хотя в топиках все показывает хорошо, и таких переменных несколько, не все.
Ниже часть журнала
Сводка
|11-04-2023 16:39:41.707 [wb-mqtt-opcua]|INFO: [OPCUA] session: SecureChannel 6 | Session ns=1;g=0e1f3c13-0dd4-e167-0380-0850db1d5145 | Subscription 2 | MonitoredItem 30 | Created the MonitoredItem|
|11-04-2023 16:39:41.707 [wb-mqtt-opcua]|INFO: [OPCUA] session: SecureChannel 6 | Session ns=1;g=0e1f3c13-0dd4-e167-0380-0850db1d5145 | Subscription 2 | MonitoredItem 29 | Created the MonitoredItem|
|11-04-2023 16:39:41.707 [wb-mqtt-opcua]|ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L2-L3Q’|
|11-04-2023 16:39:41.707 [wb-mqtt-opcua]|INFO: [OPCUA] session: SecureChannel 6 | Session ns=1;g=0e1f3c13-0dd4-e167-0380-0850db1d5145 | Subscription 2 | MonitoredItem 28 | Created the MonitoredItem|
|11-04-2023 16:39:41.707 [wb-mqtt-opcua]|ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Total S’|
|11-04-2023 16:39:41.707 [wb-mqtt-opcua]|ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Total AP energy’|
|11-04-2023 16:39:41.707 [wb-mqtt-opcua]|INFO: [OPCUA] session: SecureChannel 6 | Session ns=1;g=0e1f3c13-0dd4-e167-0380-0850db1d5145 | Subscription 2 | MonitoredItem 27 | Created the MonitoredItem|
|11-04-2023 16:39:41.707 [wb-mqtt-opcua]|INFO: [OPCUA] session: SecureChannel 6 | Session ns=1;g=0e1f3c13-0dd4-e167-0380-0850db1d5145 | Subscription 2 | MonitoredItem 26 | Created the MonitoredItem|
|11-04-2023 16:39:41.707 [wb-mqtt-opcua]|INFO: [OPCUA] session: SecureChannel 6 | Session ns=1;g=0e1f3c13-0dd4-e167-0380-0850db1d5145 | Subscription 2 | MonitoredItem 25 | Created the MonitoredItem|
|11-04-2023 16:39:41.681 [wb-mqtt-opcua]|ERROR: [OPCUA] Control is not found 'wb-map3e_128/Total Pѧ|
|11-04-2023 16:39:41.681 [wb-mqtt-opcua]|INFO: [OPCUA] session: SecureChannel 6 | Session ns=1;g=0e1f3c13-0dd4-e167-0380-0850db1d5145 | Subscription 2 | MonitoredItem 24 | Created the MonitoredItem|
В чем может быть проблема ?
Покажите пожалуйста контрол с таким именем. Он точно есть?
В том то и дело что с буквой Q на конце нет. Как и нет с ’ на конце. Проверил все от и до как на контроллере так и на стороне Scada. Но при соединении выпадают каждый раз одни и те же: Bad_DeviceFailure (0x808B0000 - There has been a failure in the device/data source that generates the value that has affected the value.); count = 17
Irms_L3
Total_Q
Urms_L2
Irms_L2
U_L3_L1
Total_RP_energy
U_L1_L2
Total_P
Total_AP_energy
Total_S
U_L2_L3
Irms_L1
Urms_L1
Urms_L3
Но он, отсутствующий контрол внесен в конфиг шлюза. Нужно исправить конфиг.
В каком конфиге его искать ?
Вот мой конфиг с контроллера
wb-mqtt-opcua.conf (38,4 КБ)
А это из Scada
Export.csv (13,0 КБ)
Вдим в логе вывод, напрмиер, как показательный.:
Обратите внимание на символ после P с кодом 1127
Видим в конфиге топик:
                    "enabled" : true,
                    "info" : "power (read only)",
                    "topic" : "wb-map3e_128/Total P"
Соответственно, топик ‘wb-map3e_128/U L2-L3Q’ в конфиге не указан совсем.
Если запрашивать отсутствующие топики - в лог на контроллере выводится ошибка.
Это не конфиг, кусок лога, интересующих топиков там нет.
Попробовал через OPС-Сервер. Идентификаторы все импортируются с контроллера
Но как запускаю опрос вылезают все равно Q на конце…
Сводка
13-04-2023 14:38:02.913 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L3-L1Q’
13-04-2023 14:38:02.913 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L1-L2Q’
13-04-2023 14:38:02.913 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L2-L3Q’
13-04-2023 14:38:02.900 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L1-L2Q’
13-04-2023 14:37:43.892 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L3-L1Q’
13-04-2023 14:37:43.892 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L1-L2Q’
13-04-2023 14:37:43.892 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L2-L3Q’
13-04-2023 14:37:43.880 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L1-L2Q’
13-04-2023 14:37:37.044 [NetworkManager] [1681385857.0441] audit: op=“connection-activate” uuid=“c3e38405-9c17-4155-ad70-664311b49066” name=“wb-eth1” pid=1684 uid=0 result=“fail” reason=“Connection ‘wb-eth1’ is not available on device eth1 because device has no carrier”
13-04-2023 14:37:36.682 [NetworkManager] [1681385856.6817] audit: op=“connection-activate” uuid=“91f1c71d-2d97-4675-886f-ecbe52b8451e” name=“wb-eth0” pid=1684 uid=0 result=“fail” reason=“Connection ‘wb-eth0’ is not available on device eth0 because device has no carrier”
13-04-2023 14:37:24.841 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L3-L1Q’
13-04-2023 14:37:24.841 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L1-L2Q’
13-04-2023 14:37:24.841 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L2-L3Q’
13-04-2023 14:37:24.826 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L1-L2Q’
13-04-2023 14:37:04.220 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L3-L1Q’
13-04-2023 14:37:04.220 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L1-L2Q’
13-04-2023 14:37:04.184 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L2-L3Q’
13-04-2023 14:37:04.184 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L1-L2Q’
Хотя везде этого нет.
Причем именно у части переменных, не у всех
Так же попробовал через простой OPC UA Client
Часть данных выходит например:
Но часть так же выдает ошибку:
А в выводе на контролере следующее:
Сводка
13-04-2023 15:16:08.225 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Irms L19’
13-04-2023 15:14:14.864 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Irms L19’
13-04-2023 15:13:42.456 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Irms L19’
13-04-2023 15:13:17.649 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Total S’
13-04-2023 15:12:29.552 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Urms L3Q’
13-04-2023 15:12:22.318 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Total S’
13-04-2023 15:12:17.209 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/U L1-L2Q’
13-04-2023 15:11:24.992 INFO: [OPCUA] session: SecureChannel 52 | Session ns=1;g=87fc3ac2-ecda-4623-0810-c17c7357a5aa | ActivateSession: Session activated
13-04-2023 15:11:24.992 INFO: [OPCUA] channel: Connection 8 | SecureChannel 52 | Session 87fc3ac2-ecda-4623-0810-c17c7357a5aa created
13-04-2023 15:11:24.992 INFO: [OPCUA] channel: Connection 8 | SecureChannel 52 | SecureChannel opened with SecurityPolicy Profile Reporting Links and a revised lifetime of 600.00s
13-04-2023 15:11:24.974 INFO: [OPCUA] network: Connection 8 | New connection over TCP from 192.168.1.77
Строки с “13-04-2023 15:12:29.552 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Urms L3Q’” относятся к какой сессии? к сессии OPC UA Client?
Можно, например, отследить сетевые пакеты - для того чтобы убедиться что запрашиваются неверные топики.
Да строки относятся к последней сессии OPC UA Client.
отследить сетевые пакеты - Как это сделать ?
Сейчас попробую вернуть к заводским контроллер и заново все сделать.
Поставить на контроллер (или на компьютер) tcpdump
и запустить его с параметрами
tcpdump -i any port 4840 -A -v
Это не имеет смысла, настроки контроллера верны.
Вот что выводит в tcpdump
Сводка
5:09:41.331052 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 151) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [P.], cksum 0x938a (correct) , seq 6786:6917, ack 7126, win 1027, length 131
......@........Y.ed/...........,.a....|.....u.....hP.......MSGF......................w......ow.B..TE......|u ..n............................A...............wb-map3e_128/Irms L1.............. 15:09:41.336348 wlan1 Out IP6 (flowlabel 0xf2047, hlim 64, next-header TCP (6) payload length: 102) fe80::2c0f:61c5:c787:57c.4082 > fe80::59af:6564:2fa3:a88b.7296: Flags [P.], cksum 0x3b5b (correct) , seq 7126:7208, ack 6917, win 501, length 82 . G.f.@…,.a…|…Y.ed/…h.u…P…;[…MSGFR…z…t…n…s…n…s…n…
15:09:41.389908 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 20) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [.], cksum 0xc408 (correct), ack 7208, win 1027, length 0
......@........Y.ed/...........,.a....|.....u......P....... 15:09:44.677016 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 128) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [P.], cksum 0xc287 (correct) , seq 6917:7025, ack 7208, win 1027, length 108 …@…Y.ed/…,.a…|…u…P…MSGFl…w…ow.B…TE…9
…n…‘…
15:09:44.677958 wlan1 Out IP6 (flowlabel 0xf2047, hlim 64, next-header TCP (6) payload length: 86) fe80::2c0f:61c5:c787:57c.4082 > fe80::59af:6564:2fa3:a88b.7296: Flags [P.], cksum 0x4bff (correct), seq 7208:7274, ack 7025, win 501, length 66
. G.V.@........,.a....|........Y.ed/............u..P...K...MSGFB.....................z..S...n................................ 15:09:44.725111 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 20) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [.], cksum 0xc35a (correct), ack 7274, win 1027, length 0 …@…Y.ed/…,.a…|…u…P…Z…
15:09:49.536099 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 992) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [P.], cksum 0x128e (correct) , seq 7025:7997, ack 7274, win 1027, length 972
......@........Y.ed/...........,.a....|.....u......P.......MSGF............ ... .....w......ow.B..TE.......x...n............................................wb-map3e_128/Ipeak L3.................... .wb-map3e_128/Ipeak L3.....................wb-map3e_128/Ipeak L3.....................wb-map3e_128/Ipeak L3.....................wb-map3e_128/Ipeak L3.....................wb-map3e_128/Ipeak L3........ .............wb-map3e_128/Ipeak L3.....................wb-map3e_128/Ipeak L3.....................wb-map3e_128/Ipeak L3 ....................wb-map3e_128/Ipeak L3 ....................wb-map3e_128/Ipeak L3.....................wb-map3e_128/Ipeak L3.....................wb-map3e_128/Ipeak L3.....................wb-map3e_128/Ipeak L3.....................wb-map3e_1 28/Ipeak L3.....................wb-map3e_128/Ipeak L3.....................wb-map3e_128/Ipeak L3.....................wb-map3e_128/Ipeak L3.....................wb-map3e_128/Ipeak L3................... ..wb-map3e_128/Ipeak L3.....................wb-map3e_128/Ipeak L3.............. 15:09:49.536741 wlan1 Out IP6 (flowlabel 0xf2047, hlim 64, next-header TCP (6) payload length: 241) fe80::2c0f:61c5:c787:57c.4082 > fe80::59af:6564:2fa3:a88b.7296: Flags [P.], cksum 0x4fbd (correct) , seq 7274:7495, ack 7997, win 501, length 221 . G…@…,.a…|…Y.ed/…u.WP…O…MSGF… … …z…n…wb-map3e_128/Ipeak L3…Ipeak L3…en-US…Ipeak L3… …5…5…5…5…5…5…5…
15:09:49.539749 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 152) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [P.], cksum 0x8fd8 (correct) , seq 7997:8129, ack 7495, win 1026, length 132
......@........Y.ed/...........,.a....|.....u.W....P.......MSGF............!...!.....w......ow.B..TE......4....n............................A...............wb-map3e_128/Ipeak L3.............. 15:09:49.540553 wlan1 Out IP6 (flowlabel 0xf2047, hlim 64, next-header TCP (6) payload length: 107) fe80::2c0f:61c5:c787:57c.4082 > fe80::59af:6564:2fa3:a88b.7296: Flags [P.], cksum 0xead3 (correct) , seq 7495:7582, ack 8129, win 501, length 87 . G.k.@…,.a…|…Y.ed/…u…P…MSGFW…!..!..z.&R…n…-0.03.Q…n…Q…n…
15:09:49.543121 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 126) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [P.], cksum 0x98e6 (correct) , seq 8129:8235, ack 7582, win 1026, length 106
....~.@........Y.ed/...........,.a....|.....u.....0P.......MSGFj..........."...".....w......ow.B..TE...........n............................A........................ 15:09:49.543632 wlan1 Out IP6 (flowlabel 0xf2047, hlim 64, next-header TCP (6) payload length: 111) fe80::2c0f:61c5:c787:57c.4082 > fe80::59af:6564:2fa3:a88b.7296: Flags [P.], cksum 0xa17b (correct) , seq 7582:7673, ack 8235, win 501, length 91 . G.o.@…,.a…|…Y.ed/…0.u.EP…{…MSGF[…“…”…z…n… …BaseDataType…n…
15:09:49.598505 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 20) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [.], cksum 0xbd13 (correct), ack 7673, win 1025, length 0
......@........Y.ed/...........,.a....|.....u.E....P....... 15:09:49.686620 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 128) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [P.], cksum 0xac13 (correct) , seq 8235:8343, ack 7673, win 1025, length 108 …@…Y.ed/…,.a…|…u.E…P…MSGFl…#…#…w…ow.B…TE…n…’…
15:09:49.687104 wlan1 Out IP6 (flowlabel 0xf2047, hlim 64, next-header TCP (6) payload length: 86) fe80::2c0f:61c5:c787:57c.4082 > fe80::59af:6564:2fa3:a88b.7296: Flags [P.], cksum 0x17aa (correct), seq 7673:7739, ack 8343, win 501, length 66
. G.V.@........,.a....|........Y.ed/............u..P.......MSGFB...........#...#.....z......n................................ 15:09:49.739868 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 20) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [.], cksum 0xbc65 (correct), ack 7739, win 1025, length 0 …@…Y.ed/…,.a…|…u…P…e…
15:09:50.966587 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 971) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [P.], cksum 0x8e58 (correct) , seq 8343:9294, ack 7739, win 1025, length 951
......@........Y.ed/...........,.a....|.....u......P....X..MSGF............$...$.....w......ow.B..TE......{....n............................................wb-map3e_128/Irms L1..................... wb-map3e_128/Irms L1.....................wb-map3e_128/Irms L1.....................wb-map3e_128/Irms L1.....................wb-map3e_128/Irms L1.....................wb-map3e_128/Irms L1.............. .......wb-map3e_128/Irms L1.....................wb-map3e_128/Irms L1.....................wb-map3e_128/Irms L1 ....................wb-map3e_128/Irms L1 ....................wb-map3e_128/Irms L1.....................wb-map3e_128/Irms L1.....................wb-map3e_128/Irms L1.....................wb-map3e_128/Irms L1.....................wb-map3e_128/I rms L1.....................wb-map3e_128/Irms L1.....................wb-map3e_128/Irms L1.....................wb-map3e_128/Irms L1.....................wb-map3e_128/Irms L1.....................wb-map3 e_128/Irms L1.....................wb-map3e_128/Irms L1.............. 15:09:50.968101 wlan1 Out IP6 (flowlabel 0xf2047, hlim 64, next-header TCP (6) payload length: 238) fe80::2c0f:61c5:c787:57c.4082 > fe80::59af:6564:2fa3:a88b.7296: Flags [P.], cksum 0x39a0 (correct) , seq 7739:7957, ack 9294, win 501, length 218 . G…@…,.a…|…Y.ed/…u.hP…9…MSGF…$…$…z…n…wb-map3e_128/Irms L1…Irms L1…en-US…Irms L1… …5…5…5…5…5…5…5…
15:09:50.975064 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 151) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [P.], cksum 0xe2bb (correct) , seq 9294:9425, ack 7957, win 1024, length 131
......@........Y.ed/...........,.a....|.....u.h....P.......MSGF............%...%.....w......ow.B..TE......~....n............................A...............wb-map3e_128/Irms L1.............. 15:09:50.986831 wlan1 Out IP6 (flowlabel 0xf2047, hlim 64, next-header TCP (6) payload length: 102) fe80::2c0f:61c5:c787:57c.4082 > fe80::59af:6564:2fa3:a88b.7296: Flags [P.], cksum 0x57aa (correct) , seq 7957:8039, ack 9425, win 501, length 82 . G.f.@…,.a…|…Y.ed/…u…P…W…MSGFR…%…%…z.,…n…n…F…n…
15:09:51.040407 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 20) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [.], cksum 0xb700 (correct), ack 8039, win 1024, length 0
......@........Y.ed/...........,.a....|.....u......P....... 15:09:54.682846 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 128) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [P.], cksum 0xd402 (correct) , seq 9425:9533, ack 8039, win 1024, length 108 …@…Y.ed/…,.a…|…u…P…MSGFl…&…&…w…ow.B…TE…n…‘…
15:09:54.683467 wlan1 Out IP6 (flowlabel 0xf2047, hlim 64, next-header TCP (6) payload length: 86) fe80::2c0f:61c5:c787:57c.4082 > fe80::59af:6564:2fa3:a88b.7296: Flags [P.], cksum 0x6432 (correct), seq 8039:8105, ack 9533, win 501, length 66
. G.V.@........,.a....|........Y.ed/............u.WP...d2..MSGFB...........&...&.....z......n................................ 15:09:54.729767 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 20) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [.], cksum 0xb652 (correct), ack 8105, win 1024, length 0 …@…Y.ed/…,.a…|…u.W…;P…R…
15:09:59.686119 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 128) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [P.], cksum 0x65df (correct) , seq 9533:9641, ack 8105, win 1024, length 108
......@........Y.ed/...........,.a....|.....u.W...;P...e...MSGFl...........'...'.....w......ow.B..TE......6@...n...............'....................................... 15:09:59.686603 wlan1 Out IP6 (flowlabel 0xf2047, hlim 64, next-header TCP (6) payload length: 86) fe80::2c0f:61c5:c787:57c.4082 > fe80::59af:6564:2fa3:a88b.7296: Flags [P.], cksum 0x7b14 (correct), seq 8105:8171, ack 9641, win 501, length 66 . G.V.@…,.a…|…Y.ed/…;.u…P…{…MSGFB…’…‘…z…|…n…
15:09:59.732832 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 20) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [.], cksum 0xb5a5 (correct), ack 8171, win 1023, length 0
......@........Y.ed/...........,.a....|.....u.....}P....... 15:10:04.700537 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 128) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [P.], cksum 0x33c2 (correct) , seq 9641:9749, ack 8171, win 1023, length 108 …@…Y.ed/…,.a…|…u…}P…3…MSGFl…(…(…w…ow.B…TE…l…n…’…
15:10:04.701456 wlan1 Out IP6 (flowlabel 0xf2047, hlim 64, next-header TCP (6) payload length: 86) fe80::2c0f:61c5:c787:57c.4082 > fe80::59af:6564:2fa3:a88b.7296: Flags [P.], cksum 0x4a34 (correct), seq 8171:8237, ack 9749, win 501, length 66
. G.V.@........,.a....|........Y.ed/..........}.u./P...J4..MSGFB...........(...(.....z......n................................ 15:10:04.747142 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 20) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [.], cksum 0xb4f1 (correct), ack 8237, win 1029, length 0 …@…Y.ed/…,.a…|…u./…P…
15:10:09.707532 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 128) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [P.], cksum 0x2ada (correct), seq 9749:9857, ack 8237, win 1029, length 108
......@........Y.ed/...........,.a....|.....u./....P...*...MSGFl...........)...).....w......ow.B..TE.......o. .n...............'....................................... 15:10:09.708038 wlan1 Out IP6 (flowlabel 0xf2047, hlim 64, next-header TCP (6) payload length: 86) fe80::2c0f:61c5:c787:57c.4082 > fe80::59af:6564:2fa3:a88b.7296: Flags [P.], cksum 0x4a8c (correct), seq 8237:8303, ack 9857, win 501, length 66 . G.V.@…,.a…|…Y.ed/…u…P…J…MSGFB…)…)…z… .n…
15:10:09.754032 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 20) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [.], cksum 0xb443 (correct), ack 8303, win 1029, length 0
......@........Y.ed/...........,.a....|.....u......P....C.. 15:10:14.720493 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 128) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [P.], cksum 0x35e9 (correct), seq 9857:9965, ack 8303, win 1029, length 108 …@…Y.ed/…,.a…|…u…P…5…MSGFl………w…ow.B…TE…$_…n…'…
15:10:14.721435 wlan1 Out IP6 (flowlabel 0xf2047, hlim 64, next-header TCP (6) payload length: 86) fe80::2c0f:61c5:c787:57c.4082 > fe80::59af:6564:2fa3:a88b.7296: Flags [P.], cksum 0xf9e4 (correct), seq 8303:8369, ack 9965, win 501, length 66
. G.V.@........,.a....|........Y.ed/............u..P.......MSGFB...........*...*.....z.(....n................................ 15:10:14.767158 wlan1 In IP6 (flowlabel 0xec4f6, hlim 64, next-header TCP (6) payload length: 20) fe80::59af:6564:2fa3:a88b.7296 > fe80::2c0f:61c5:c787:57c.4082: Flags [.], cksum 0xb396 (correct), ack 8369, win 1028, length 0 …@…Y.ed/…,.a…|…u…CP…
А это в то же время на контроллере:
Сводка
13-04-2023 18:11:15.099 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Irms L19’
13-04-2023 18:09:50.978 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Irms L19’
13-04-2023 18:09:41.333 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Irms L19’
13-04-2023 18:08:34.509 INFO: [OPCUA] session: SecureChannel 8
13-04-2023 18:08:34.509 INFO: [OPCUA] channel: Connection 8
13-04-2023 18:08:34.463 INFO: [OPCUA] network: Connection 8
13-04-2023 18:08:33.462 INFO: [OPCUA] network: Connection 8
13-04-2023 18:08:33.462 INFO: [OPCUA] channel: Connection 8
13-04-2023 18:08:33.440 INFO: [OPCUA] network: Connection 8
13-04-2023 18:08:23.633 INFO: [OPCUA] network: Connection 8
13-04-2023 18:08:23.633 INFO: [OPCUA] channel: Connection 8
13-04-2023 18:08:23.627 INFO: [OPCUA] session: SecureChannel 6
13-04-2023 18:07:11.560 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Irms L19’
Отлично, благодарю. Попробую воспроизвести. А при работе по ipv4 - так же?
По IP4 сейчас попробую.
На другом контроллере 7.3.4B/3 678 AZ5IXD7F testing ( со всеми обновлениями)
Все тоже самое.
Сводка
14-04-2023 09:07:42.131 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Irms L3’
14-04-2023 09:07:39.369 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Irms L2’
14-04-2023 09:07:34.797 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found 'wb-map3e_128/Irms L1�
14-04-2023 09:07:19.325 [wb-mqtt-opcua] INFO: [OPCUA] session: SecureChannel 4
14-04-2023 09:07:19.320 [wb-mqtt-opcua] INFO: [OPCUA] channel: Connection 8
14-04-2023 09:07:19.317 [wb-mqtt-opcua] INFO: [OPCUA] network: Connection 8
14-04-2023 09:07:17.292 [wb-mqtt-opcua] INFO: [OPCUA] network: Connection 8
14-04-2023 09:07:17.291 [wb-mqtt-opcua] INFO: [OPCUA] channel: Connection 8
14-04-2023 09:07:17.287 [wb-mqtt-opcua] INFO: [OPCUA] channel: Connection 8
14-04-2023 09:07:17.284 [wb-mqtt-opcua] INFO: [OPCUA] network: Connection 8
14-04-2023 09:07:14.871 [wb-mqtt-opcua] INFO: [OPCUA] network: Connection 8
14-04-2023 09:07:14.871 [wb-mqtt-opcua] INFO: [OPCUA] channel: Connection 8
14-04-2023 09:07:14.868 [wb-mqtt-opcua] INFO: [OPCUA] channel: Connection 8
14-04-2023 09:07:14.867 [wb-mqtt-opcua] INFO: [OPCUA] network: Connection 8
14-04-2023 09:07:14.855 [wb-mqtt-opcua] INFO: [OPCUA] network: Connection 8
14-04-2023 09:07:14.854 [wb-mqtt-opcua] INFO: [OPCUA] channel: Connection 8
14-04-2023 09:07:14.826 [wb-mqtt-opcua] INFO: [OPCUA] channel: Connection 8
14-04-2023 09:07:14.808 [wb-mqtt-opcua] INFO: [OPCUA] network: Connection 8
14-04-2023 09:04:41.092 [wb-mqtt-serial] WARNING: [serial client] </dev/ttyRS485-2 115200 8 N 2> Register read rate limit is exceeded
Подключил MAP6S все читается без ошибок
Все тоже самое
Понятно, похоже бага. Думаю, разберемся с программистами.
Похоже явно что то не так… Контроллер 6.9.1A/1G3 606 staging.06694.cf98af374eb4 Release suite
testing.
18-04-2023 09:54:21.130 [wb-mqtt-opcua] ERROR: [OPCUA] Control is not found 'pulsar-heat_8562224/Status’
Чем только не проверял… результат везде один и тот же… правда не у всех устройств.
И заметил, что иногда пропадает ошибка у 1-2 топиков. Если попробовать сделать Даунгрейд и заново все прописать возможно получиться ?
Wiren Board 6.8.2 (s/n AGRJZZR2), release wb-2207 (as stable) все тоже самое и те же топики
Сводка
18-04-2023 12:02:24.916 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Urms L3’
18-04-2023 12:02:24.916 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Urms L2!’
18-04-2023 12:02:24.916 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Urms L1’
18-04-2023 12:02:24.879 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Total S’
18-04-2023 12:02:24.879 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Total RP energy’
18-04-2023 12:02:24.879 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Total Q’
18-04-2023 12:02:24.879 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Total P’
18-04-2023 12:02:24.879 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Total AP energy’
18-04-2023 12:02:24.863 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Irms L39’
18-04-2023 12:02:24.863 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Irms L2Q’
18-04-2023 12:02:24.857 ERROR: [OPCUA] Control is not found ‘wb-map3e_128/Irms L1!’
Да, поведение воспроизводится, в том числе синтетически. бага отдана программистам, ждем исправления.
