Ошибка в облаке
пакет wb-cloud-agent был установлен
root@wirenboard-A2TGS2AG:~# dpkg -s wb-suite
Package: wb-suite
Status: install ok installed
Priority: standard
Section: metapackages
Installed-Size: 8
Maintainer: Wiren Board team <info@wirenboard.com>
Architecture: all
Source: wb-metapackages
Version: 1.19.8
Depends: wb-essential, wb-knxd-config, wb-update-manager, wb-nm-helper, wb-mqtt-w1, wb-mqtt-gpio, wb-mqtt-adc, wb-mqtt-serial, wb-mqtt-dac, wb-rules, wb-rules-system, wb-mqtt-db, wb-mqtt-db-cli, wb-mqtt-mbgate, wb-mqtt-homeui, wb-mqtt-knx, wb-mcu-fw-flasher, wb-mcu-fw-updater, wb-device-manager, wb-mqtt-confed, wb-mqtt-opcua, wb-mqtt-logs, wb-diag-collect, wb-mqtt-metrics, wb-mqtt-iec104, wb-cloud-agent, wb-scenarios
Recommends: wb-update-notifier, mc, gpiod, modbus-utils-rpc, serial-tool, mmc-utils, python3-serial, wb-modbus-ext-scanner
Breaks: wb-test-suite-deps (<= 1.12.0)
Description: Wirenboard vendor software set
 This metapackage pulls in all the packages from Wirenboard vendor
Homepage: https://github.com/wirenboard/wb-metapackages
После обновления и переустановки проблема решилась.
root@wirenboard-A2TGS2AG:~# apt update && apt reinstall wb-cloud-agent
Hit:2 https://debian-mirror.wirenboard.com/debian bullseye InRelease
Hit:1 https://deb.wirenboard.com/wb7/bullseye stable InRelease
Hit:3 https://debian-mirror.wirenboard.com/debian bullseye-updates InRelease
Hit:4 https://debian-mirror.wirenboard.com/debian-security bullseye-security InRelease
Reading package lists... Done
Building dependency tree... Done
4 packages can be upgraded. Run 'apt list --upgradable' to see them.
The following package was automatically installed and is no longer required:
  python3-tabulate
Use 'apt autoremove' to remove it.
  wb-cloud-agent
1 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
Need to get 12.4 kB of archives.
After this operation, 19.5 kB disk space will be freed.
Get:1 https://deb.wirenboard.com/wb7/bullseye stable/main armhf wb-cloud-agent all 1.6.2-wb100 [12.4 kB]
Fetched 12.4 kB in 1s (19.2 kB/s)
(Reading database ... 40162 files and directories currently installed.)
Preparing to unpack .../wb-cloud-agent_1.6.2-wb100_all.deb ...
Unpacking wb-cloud-agent (1.6.2-wb100) over (1.6.2) ...
Setting up wb-cloud-agent (1.6.2-wb100) ...
Created symlink /etc/systemd/system/multi-user.target.wants/wb-cloud-agent.service → /lib/systemd/system/wb-cloud-agent.service.
Спасибо
