Прошу помочь с решением проблемы. Решил проверить обновления, при отправке команды выдает кучу ошибок.
Спойлер
root@wirenboard-AHVP5LSS:~# apt update && apt upgrade && reboot
Err:1 http://debian-mirror.wirenboard.com/debian` bullseye InRelease Could not resolve ‘debian-mirror.wirenboard.com’ Err:2 http://debian-mirror.wirenboard.com/debian bullseye-updates InRelease Could not resolve ‘debian-mirror.wirenboard.com’ Err:3 https://download.docker.com/linux/debian bullseye InRelease Could not resolve ‘download.docker.com’ Err:4 http://debian-mirror.wirenboard.com/debian-security bullseye-security InRelease Could not resolve ‘debian-mirror.wirenboard.com’ Err:5 http://deb.wirenboard.com/wb8/bullseye stable InRelease Could not resolve ‘deb.wirenboard.com’ Reading package lists… Done Building dependency tree… Done Reading state information… Done 71 packages can be upgraded. Run ‘apt list --upgradable’ to see them. W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye/InRelease Could not resolve ‘debian-mirror.wirenboard.com’ W: Failed to fetch http://debian-mirror.wirenboard.com/debian/dists/bullseye-updates/InRelease Could not resolve ‘debian-mirror.wirenboard.com’ W: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/dists/bullseye-security/InRelease Could not resolve ‘debian-mirror.wirenboard.com’ W: Failed to fetch https://download.docker.com/linux/debian/dists/bullseye/InRelease Could not resolve ‘download.docker.com’ W: Failed to fetch http://deb.wirenboard.com/wb8/bullseye/dists/stable/InRelease Could not resolve ‘deb.wirenboard.com’ W: Some index files failed to download. They have been ignored, or old ones used instead. Reading package lists… Done Building dependency tree… Done Reading state information… Done Calculating upgrade… Done The following packages were automatically installed and are no longer required: libltdl7 libslirp0 libwbmqtt1-4 python3-all python3-distutils python3-lib2to3 python3-wb-mqtt-metrics python3-wb-update-manager slirp4netns telegraf-wb-cloud-agent Use ‘apt autoremove’ to remove them. The following packages will be upgraded: bind9-host bind9-libs containerd.io distro-info-data docker-buildx-plugin docker-ce docker-ce-cli docker-ce-rootless-extras docker-compose-plugin libnghttp2-14 libnginx-mod-http-auth-pam libnginx-mod-http-cache-purge libnginx-mod-http-dav-ext libnginx-mod-http-echo libnginx-mod-http-fancyindex libnginx-mod-http-geoip libnginx-mod-http-geoip2 libnginx-mod-http-headers-more-filter libnginx-mod-http-image-filter libnginx-mod-http-lua libnginx-mod-http-ndk libnginx-mod-http-perl libnginx-mod-http-subs-filter libnginx-mod-http-uploadprogress libnginx-mod-http-upstream-fair libnginx-mod-http-xslt-filter libnginx-mod-mail libnginx-mod-nchan libnginx-mod-stream libnginx-mod-stream-geoip libnginx-mod-stream-geoip2 libnss-systemd libpam-systemd libperl5.32 libpng16-16 libpolkit-agent-1-0 libpolkit-gobject-1-0 libpython3.9-minimal libpython3.9-stdlib libsystemd0 libtiff5 libudev1 nginx-common nginx-extras openssh-client openssh-server openssh-sftp-server perl perl-base perl-modules-5.32 policykit-1 python3-wb-mqtt-metrics python3-wb-update-manager python3.9 python3.9-minimal rsync systemd systemd-sysv tzdata u-boot-tools-wb u-boot-wb8 udev wb-cloud-agent wb-configs wb-homeui-backend wb-mqtt-homeui wb-mqtt-metrics wb-mqtt-serial wb-release-info wb-update-manager wb-utils 71 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 119 MB of archives. After this operation, 14.7 MB disk space will be freed. Do you want to continue? [Y/n] Y Ign:1 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 perl-modules-5.32 all 5.32.1-4+deb11u5 Err:2 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libperl5.32 arm64 5.32.1-4+deb11u5 Could not resolve ‘debian-mirror.wirenboard.com’ Err:3 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 perl-base arm64 5.32.1-4+deb11u5 Could not resolve ‘debian-mirror.wirenboard.com’ Err:4 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 perl arm64 5.32.1-4+deb11u5 Could not resolve ‘debian-mirror.wirenboard.com’ Err:5 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnss-systemd arm64 247.3-7+deb11u8 Could not resolve ‘debian-mirror.wirenboard.com’ Err:6 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libudev1 arm64 247.3-7+deb11u8 Could not resolve ‘debian-mirror.wirenboard.com’ Err:7 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 udev arm64 247.3-7+deb11u8 Could not resolve ‘debian-mirror.wirenboard.com’ Err:8 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libpam-systemd arm64 247.3-7+deb11u8 Could not resolve ‘debian-mirror.wirenboard.com’ Err:9 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libsystemd0 arm64 247.3-7+deb11u8 Could not resolve ‘debian-mirror.wirenboard.com’ Err:10 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 systemd arm64 247.3-7+deb11u8 Could not resolve ‘debian-mirror.wirenboard.com’ Err:11 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 systemd-sysv arm64 247.3-7+deb11u8 Could not resolve ‘debian-mirror.wirenboard.com’ Err:12 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libpython3.9-minimal arm64 3.9.2-1+deb11u7 Could not resolve ‘debian-mirror.wirenboard.com’ Err:13 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libpython3.9-stdlib arm64 3.9.2-1+deb11u7 Could not resolve ‘debian-mirror.wirenboard.com’ Err:14 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 python3.9-minimal arm64 3.9.2-1+deb11u7 Could not resolve ‘debian-mirror.wirenboard.com’ Err:15 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 python3.9 arm64 3.9.2-1+deb11u7 Could not resolve ‘debian-mirror.wirenboard.com’ Ign:16 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 tzdata all 2026b-0+deb11u1 Err:17 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 u-boot-tools-wb arm64 2:2025.04+wb1.0.0 Could not resolve ‘deb.wirenboard.com’ Ign:18 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-utils all 4.27.7 Ign:19 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-release-info all 1.0-stable~wb8+bullseye~20260514154335 Err:20 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-mqtt-serial arm64 2.224.0-wb106 Could not resolve ‘deb.wirenboard.com’ Ign:21 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-configs all 3.50.1 Ign:22 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-mqtt-homeui all 2.172.0-wb112 Ign:23 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-homeui-backend all 2.172.0-wb112 Err:24 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 u-boot-wb8 arm64 2:2025.04+wb1.0.0 Could not resolve ‘deb.wirenboard.com’ Ign:25 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 python3-wb-update-manager all 1.4.0 Ign:26 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-update-manager all 1.4.0 Err:27 https://download.docker.com/linux/debian bullseye/stable arm64 docker-ce-cli arm64 5:29.5.2-1~debian.11~bullseye Could not resolve ‘download.docker.com’ Err:28 https://download.docker.com/linux/debian bullseye/stable arm64 containerd.io arm64 2.2.3-1~debian.11~bullseye Could not resolve ‘download.docker.com’ Err:29 https://download.docker.com/linux/debian bullseye/stable arm64 docker-ce arm64 5:29.5.2-1~debian.11~bullseye Could not resolve ‘download.docker.com’ Err:30 https://download.docker.com/linux/debian bullseye/stable arm64 docker-buildx-plugin arm64 0.34.0-1~debian.11~bullseye Could not resolve ‘download.docker.com’ Err:31 https://download.docker.com/linux/debian bullseye/stable arm64 docker-ce-rootless-extras arm64 5:29.5.2-1~debian.11~bullseye Could not resolve ‘download.docker.com’ Err:32 https://download.docker.com/linux/debian bullseye/stable arm64 docker-compose-plugin arm64 5.1.4-1~debian.11~bullseye Could not resolve ‘download.docker.com’ Err:33 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 rsync arm64 3.2.3-4+deb11u4 Could not resolve ‘debian-mirror.wirenboard.com’ Ign:34 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 nginx-common all 1.18.0-6.1+deb11u6 Err:35 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-cache-purge arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:36 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-dav-ext arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:37 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-echo arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:38 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-fancyindex arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:39 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-geoip arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:40 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-geoip2 arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:41 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-headers-more-filter arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:42 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-image-filter arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Ign:43 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 python3-wb-mqtt-metrics all 0.5.0 Ign:44 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-mqtt-metrics all 0.5.0 Ign:45 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-cloud-agent all 1.7.1 Err:18 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-utils all 4.27.7 Could not resolve ‘deb.wirenboard.com’ Err:19 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-release-info all 1.0-stable~wb8+bullseye~20260514154335 Could not resolve ‘deb.wirenboard.com’ Err:21 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-configs all 3.50.1 Could not resolve ‘deb.wirenboard.com’ Err:22 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-mqtt-homeui all 2.172.0-wb112 Could not resolve ‘deb.wirenboard.com’ Err:23 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-homeui-backend all 2.172.0-wb112 Could not resolve ‘deb.wirenboard.com’ Err:25 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 python3-wb-update-manager all 1.4.0 Could not resolve ‘deb.wirenboard.com’ Err:46 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-ndk arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:47 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-lua arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:48 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-perl arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:49 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-subs-filter arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:50 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-uploadprogress arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:51 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-upstream-fair arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:52 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-xslt-filter arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:26 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-update-manager all 1.4.0 Could not resolve ‘deb.wirenboard.com’ Err:43 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 python3-wb-mqtt-metrics all 0.5.0 Could not resolve ‘deb.wirenboard.com’ Err:44 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-mqtt-metrics all 0.5.0 Could not resolve ‘deb.wirenboard.com’ Err:45 http://deb.wirenboard.com/wb8/bullseye stable/main arm64 wb-cloud-agent all 1.7.1 Could not resolve ‘deb.wirenboard.com’ Err:53 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-mail arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:54 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-nchan arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:55 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-stream arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:56 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-stream-geoip2 arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:57 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-http-auth-pam arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:58 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnginx-mod-stream-geoip arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:59 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 nginx-extras arm64 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:60 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libpng16-16 arm64 1.6.37-3+deb11u4 Could not resolve ‘debian-mirror.wirenboard.com’ Err:61 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libtiff5 arm64 4.2.0-1+deb11u8 Could not resolve ‘debian-mirror.wirenboard.com’ Err:62 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 bind9-libs arm64 1:9.16.50-1~deb11u5 Could not resolve ‘debian-mirror.wirenboard.com’ Err:63 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 bind9-host arm64 1:9.16.50-1~deb11u5 Could not resolve ‘debian-mirror.wirenboard.com’ Err:64 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 openssh-sftp-server arm64 1:8.4p1-5+deb11u7 Could not resolve ‘debian-mirror.wirenboard.com’ Err:65 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 openssh-server arm64 1:8.4p1-5+deb11u7 Could not resolve ‘debian-mirror.wirenboard.com’ Err:66 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 openssh-client arm64 1:8.4p1-5+deb11u7 Could not resolve ‘debian-mirror.wirenboard.com’ Ign:67 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 distro-info-data all 0.51+deb11u11 Err:68 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libnghttp2-14 arm64 1.43.0-1+deb11u3 Could not resolve ‘debian-mirror.wirenboard.com’ Err:69 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 policykit-1 arm64 0.105-31+deb11u2 Could not resolve ‘debian-mirror.wirenboard.com’ Err:70 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libpolkit-agent-1-0 arm64 0.105-31+deb11u2 Could not resolve ‘debian-mirror.wirenboard.com’ Err:71 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 libpolkit-gobject-1-0 arm64 0.105-31+deb11u2 Could not resolve ‘debian-mirror.wirenboard.com’ Err:1 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 perl-modules-5.32 all 5.32.1-4+deb11u5 Could not resolve ‘debian-mirror.wirenboard.com’ Err:16 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 tzdata all 2026b-0+deb11u1 Could not resolve ‘debian-mirror.wirenboard.com’ Err:34 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 nginx-common all 1.18.0-6.1+deb11u6 Could not resolve ‘debian-mirror.wirenboard.com’ Err:67 http://debian-mirror.wirenboard.com/debian-security bullseye-security/main arm64 distro-info-data all 0.51+deb11u11 Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/p/perl/perl-modules-5.32_5.32.1-4%2Bdeb11u5_all.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/p/perl/libperl5.32_5.32.1-4%2Bdeb11u5_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/p/perl/perl-base_5.32.1-4%2Bdeb11u5_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/p/perl/perl_5.32.1-4%2Bdeb11u5_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/s/systemd/libnss-systemd_247.3-7%2Bdeb11u8_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/s/systemd/libudev1_247.3-7%2Bdeb11u8_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/s/systemd/udev_247.3-7%2Bdeb11u8_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/s/systemd/libpam-systemd_247.3-7%2Bdeb11u8_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/s/systemd/libsystemd0_247.3-7%2Bdeb11u8_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/s/systemd/systemd_247.3-7%2Bdeb11u8_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/s/systemd/systemd-sysv_247.3-7%2Bdeb11u8_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/p/python3.9/libpython3.9-minimal_3.9.2-1%2Bdeb11u7_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/p/python3.9/libpython3.9-stdlib_3.9.2-1%2Bdeb11u7_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/p/python3.9/python3.9-minimal_3.9.2-1%2Bdeb11u7_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/p/python3.9/python3.9_3.9.2-1%2Bdeb11u7_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/t/tzdata/tzdata_2026b-0%2Bdeb11u1_all.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/r/rsync/rsync_3.2.3-4%2Bdeb11u4_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/nginx-common_1.18.0-6.1%2Bdeb11u6_all.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-cache-purge_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-dav-ext_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-echo_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-fancyindex_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-geoip_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-geoip2_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-headers-more-filter_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-image-filter_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-ndk_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-lua_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-perl_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-subs-filter_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-uploadprogress_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-upstream-fair_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-xslt-filter_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-mail_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-nchan_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-stream_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-stream-geoip2_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-http-auth-pam_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/libnginx-mod-stream-geoip_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nginx/nginx-extras_1.18.0-6.1%2Bdeb11u6_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://deb.wirenboard.com/wb8/bullseye/pool/main/u/u-boot/u-boot-tools-wb_2025.04%2Bwb1.0.0_arm64.deb Could not resolve ‘deb.wirenboard.com’ E: Failed to fetch http://deb.wirenboard.com/wb8/bullseye/pool/main/w/wb-utils/wb-utils_4.27.7_all.deb Could not resolve ‘deb.wirenboard.com’ E: Failed to fetch http://deb.wirenboard.com/wb8/bullseye/pool/main/w/wb-release-info/wb-release-info_1.0-stable~wb8%2Bbullseye~20260514154335_all.deb Could not resolve ‘deb.wirenboard.com’ E: Failed to fetch http://deb.wirenboard.com/wb8/bullseye/pool/main/w/wb-mqtt-serial/wb-mqtt-serial_2.224.0-wb106_arm64.deb Could not resolve ‘deb.wirenboard.com’ E: Failed to fetch http://deb.wirenboard.com/wb8/bullseye/pool/main/w/wb-configs/wb-configs_3.50.1_all.deb Could not resolve ‘deb.wirenboard.com’ E: Failed to fetch http://deb.wirenboard.com/wb8/bullseye/pool/main/w/wb-mqtt-homeui/wb-mqtt-homeui_2.172.0-wb112_all.deb Could not resolve ‘deb.wirenboard.com’ E: Failed to fetch http://deb.wirenboard.com/wb8/bullseye/pool/main/w/wb-mqtt-homeui/wb-homeui-backend_2.172.0-wb112_all.deb Could not resolve ‘deb.wirenboard.com’ E: Failed to fetch https://download.docker.com/linux/debian/dists/bullseye/pool/stable/arm64/docker-ce-cli_29.5.2-1~debian.11~bullseye_arm64.deb Could not resolve ‘download.docker.com’ E: Failed to fetch https://download.docker.com/linux/debian/dists/bullseye/pool/stable/arm64/containerd.io_2.2.3-1~debian.11~bullseye_arm64.deb Could not resolve ‘download.docker.com’ E: Failed to fetch https://download.docker.com/linux/debian/dists/bullseye/pool/stable/arm64/docker-ce_29.5.2-1~debian.11~bullseye_arm64.deb Could not resolve ‘download.docker.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/libp/libpng1.6/libpng16-16_1.6.37-3%2Bdeb11u4_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/t/tiff/libtiff5_4.2.0-1%2Bdeb11u8_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://deb.wirenboard.com/wb8/bullseye/pool/main/u/u-boot/u-boot-wb8_2025.04%2Bwb1.0.0_arm64.deb Could not resolve ‘deb.wirenboard.com’ E: Failed to fetch http://deb.wirenboard.com/wb8/bullseye/pool/main/w/wb-update-manager/python3-wb-update-manager_1.4.0_all.deb Could not resolve ‘deb.wirenboard.com’ E: Failed to fetch http://deb.wirenboard.com/wb8/bullseye/pool/main/w/wb-update-manager/wb-update-manager_1.4.0_all.deb Could not resolve ‘deb.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/b/bind9/bind9-libs_9.16.50-1~deb11u5_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/b/bind9/bind9-host_9.16.50-1~deb11u5_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/o/openssh/openssh-sftp-server_8.4p1-5%2Bdeb11u7_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/o/openssh/openssh-server_8.4p1-5%2Bdeb11u7_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/o/openssh/openssh-client_8.4p1-5%2Bdeb11u7_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/d/distro-info-data/distro-info-data_0.51%2Bdeb11u11_all.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch https://download.docker.com/linux/debian/dists/bullseye/pool/stable/arm64/docker-buildx-plugin_0.34.0-1~debian.11~bullseye_arm64.deb Could not resolve ‘download.docker.com’ E: Failed to fetch https://download.docker.com/linux/debian/dists/bullseye/pool/stable/arm64/docker-ce-rootless-extras_29.5.2-1~debian.11~bullseye_arm64.deb Could not resolve ‘download.docker.com’ E: Failed to fetch https://download.docker.com/linux/debian/dists/bullseye/pool/stable/arm64/docker-compose-plugin_5.1.4-1~debian.11~bullseye_arm64.deb Could not resolve ‘download.docker.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/n/nghttp2/libnghttp2-14_1.43.0-1%2Bdeb11u3_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/p/policykit-1/policykit-1_0.105-31%2Bdeb11u2_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/p/policykit-1/libpolkit-agent-1-0_0.105-31%2Bdeb11u2_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Failed to fetch http://debian-mirror.wirenboard.com/debian-security/pool/updates/main/p/policykit-1/libpolkit-gobject-1-0_0.105-31%2Bdeb11u2_arm64.deb Could not resolve ‘debian-mirror.wirenboard.com’ E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?`
Также проблема с подключением через облако. При обновлении пакета wb-cloud-agent, тоже куча ошибок.
Приложил файл диагностики
