Постоянно вылетает связь с cloud
Добрый день, постоянно отваливается связь с облаком у контроллера Wiren Board 8.4.4 (s/n AQJQZNOU), release wb-2504 (as stable).
root@wirenboard-AQJQZNOU:~# systemctl status wb-cloud-agent@wirenboard.cloud
● wb-cloud-agent@wirenboard.cloud.service - Wiren Board Cloud Agent (wirenboard.cloud)
Loaded: loaded (/lib/systemd/system/wb-cloud-agent@.service; disabled; vendor preset: enabled)
Active: inactive (dead)
Aug 27 10:57:33 wirenboard-AQJQZNOU systemd[1]: Condition check resulted in Wiren Board Cloud Agent (wirenboard.cloud) being skipped
root@wirenboard-AQJQZNOU:~# curl --connect-timeout 45 --retry 8 --retry-delay 1 --retry-all-errors --cert /var/lib/wb-cloud-agent/device_bundle.crt.pem --engine ateccx08 --key ATECCx08:00:02:C0:00 --key-type ENG -w ‘|||{“code”:“%{response_code}”}’ https://agent.wirenboard.cloud/api-agent/v1/agent-start-up/
curl: (58) failed to load private key from crypto engine
Warning: Problem (retrying all errors). Will retry in 1 seconds. 8 retries
Warning: left.
Warning: Problem (retrying all errors). Will retry in 1 seconds. 7 retries
Warning: left.
Warning: Problem (retrying all errors). Will retry in 1 seconds. 6 retries
Warning: left.
Warning: Problem (retrying all errors). Will retry in 1 seconds. 5 retries
Warning: left.
Warning: Problem (retrying all errors). Will retry in 1 seconds. 4 retries
Warning: left.
Warning: Problem (retrying all errors). Will retry in 1 seconds. 3 retries
Warning: left.
Warning: Problem (retrying all errors). Will retry in 1 seconds. 2 retries
Warning: left.
Warning: Problem (retrying all errors). Will retry in 1 seconds. 1 retries
Warning: left.
|||{“code”:“000”}root@wirenboard-AQJQZNOU:~#
А сам сервис - почему (зачем) выключен?
Загрузите пожалуйста диагностический архив с контроллера.
Обновите пакеты, актуальный релиз 2507.
Предварительно:
apt update; apt install -y atecc-util
Ну и покажите результат выполнения
atecc -b2 -cserial
root@wirenboard-AQJQZNOU:~# atecc -b2 -cserial
0123eaf3bb01ff44ee
После обновления работает, но не знаю на долго ли это
diag_output_AQJQZNOU_2025-08-27-15.26.13.zip (307,1 КБ)
Так, отлично. Если воспроизведется снова - напишите пожалуйста.
Хорошо
