WB 8.5.2 не загружается после сброса на заводские установки
WB 8.5.2 release wb-2504 (as stable). После сброса на заводские установки, через web интерфейс, начал циклически перезагружаться. Как решить данную проблему.
26-06-2025 11:40:05.544 [wb-mqtt-opcua] ERROR: [main] All groups are disabled, stopping service gracefully
26-06-2025 11:40:05.302 [wb-mqtt-iec104] ERROR: [main] All groups are disabled in config file, stopping service gracefully
26-06-2025 11:40:05.173 [wb-mqtt-mbgate] ERROR: [mbgate] All channels are disabled, stopping service gracefully
26-06-2025 11:40:04.761 [wpa_supplicant] Using interface wlan0 with hwaddr 78:22:88:76:20:17 and ssid “WirenBoard-AFKZ4JY7”
26-06-2025 11:40:04.109 [ntp] unable to create socket on eth0 (5) for fe80::eb39:3fa8:68bd:75c4%2#123
26-06-2025 11:40:04.109 [ntp] bind(21) AF_INET6 fe80::eb39:3fa8:68bd:75c4%2#123 flags 0x11 failed: Cannot assign requested address
26-06-2025 11:40:01.011 [wpa_supplicant] nl80211: kernel reports: Authentication algorithm number required
26-06-2025 11:40:00.924 [wpa_supplicant] nl80211: kernel reports: Authentication algorithm number required
26-06-2025 11:39:58.964 [bluetooth] sap-server: Operation not permitted (1)
26-06-2025 11:39:58.964 [bluetooth] profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
26-06-2025 11:39:56.945 debugfs: Directory ‘1100000.mixer’ with parent ‘regmap’ already present!
26-06-2025 11:39:55.464 mdio_bus gpio-1: ethernet-phy has invalid PHY address
26-06-2025 11:39:55.464 mdio_bus gpio-0: ethernet-phy has invalid PHY address
26-06-2025 11:39:30.108 debugfs: Directory ‘1100000.mixer’ with parent ‘regmap’ already present!
26-06-2025 11:39:28.570 mdio_bus gpio-1: ethernet-phy has invalid PHY address
26-06-2025 11:39:28.570 mdio_bus gpio-0: ethernet-phy has invalid PHY address
26-06-2025 11:39:03.244 debugfs: Directory ‘1100000.mixer’ with parent ‘regmap’ already present!
26-06-2025 11:39:01.580 mdio_bus gpio-1: ethernet-phy has invalid PHY address
26-06-2025 11:39:01.579 mdio_bus gpio-0: ethernet-phy has invalid PHY address
26-06-2025 11:38:36.046 debugfs: Directory ‘1100000.mixer’ with parent ‘regmap’ already present!
26-06-2025 11:38:34.513 mdio_bus gpio-1: ethernet-phy has invalid PHY address
26-06-2025 11:38:34.512 mdio_bus gpio-0: ethernet-phy has invalid PHY address
26-06-2025 11:38:03.202 [wpa_supplicant] nl80211: kernel reports: Authentication algorithm number required
26-06-2025 11:37:59.859 [netplug] caught signal 15 - exiting
26-06-2025 11:37:58.931 [wb-mqtt-logs] ERROR: [mqtt] loop_stop error: MOSQ_ERR_INVAL
26-06-2025 11:37:58.931 [wb-mqtt-logs] ERROR: [mqtt] disconnect error: MOSQ_ERR_NO_CONN
26-06-2025 11:28:33.277 [ntp] unable to create socket on dbg0 (11) for fe80::1855:89ff:fea2:6943%6#123
26-06-2025 11:28:33.277 [ntp] bind(28) AF_INET6 fe80::1855:89ff:fea2:6943%6#123 flags 0x11 failed: Cannot assign requested address
26-06-2025 11:28:27.865 [wb-mqtt-opcua] ERROR: [main] All groups are disabled, stopping service gracefully
26-06-2025 11:28:27.864 [wb-mqtt-iec104] ERROR: [main] All groups are disabled in config file, stopping service gracefully
26-06-2025 11:28:27.488 [wb-mqtt-mbgate] ERROR: [mbgate] All channels are disabled, stopping service gracefully
26-06-2025 11:28:26.519 [ntp] unable to create socket on wlan0 (7) for fe80::7a22:88ff:fe76:2017%4#123
26-06-2025 11:28:26.519 [ntp] bind(22) AF_INET6 fe80::7a22:88ff:fe76:2017%4#123 flags 0x11 failed: Cannot assign requested address
26-06-2025 11:28:26.519 [ntp] unable to create socket on eth0 (6) for fe80::eb39:3fa8:68bd:75c4%2#123
26-06-2025 11:28:26.519 [ntp] bind(22) AF_INET6 fe80::eb39:3fa8:68bd:75c4%2#123 flags 0x11 failed: Cannot assign requested address
26-06-2025 11:28:24.200 [wpa_supplicant] Using interface wlan0 with hwaddr 78:22:88:76:20:17 and ssid “WirenBoard-AFKZ4JY7”
26-06-2025 11:28:20.554 [wpa_supplicant] nl80211: kernel reports: Authentication algorithm number required
26-06-2025 11:28:20.447 [wpa_supplicant] nl80211: kernel reports: Authentication algorithm number required
26-06-2025 11:28:18.183 [bluetooth] Failed to add UUID: Failed (0x03)
26-06-2025 11:28:18.183 [bluetooth] Failed to clear UUIDs: Failed (0x03)
26-06-2025 11:28:18.183 [bluetooth] sap-server: Operation not permitted (1)
26-06-2025 11:28:18.182 [bluetooth] profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
26-06-2025 11:28:14.484 debugfs: Directory ‘1100000.mixer’ with parent ‘regmap’ already present!
26-06-2025 11:28:12.942 mdio_bus gpio-1: ethernet-phy has invalid PHY address
26-06-2025 11:28:12.941 mdio_bus gpio-0: ethernet-phy has invalid PHY address
(148,0 КБ)
В логах не вижу точной причины перезагрузки.
Попробуйте отключить Watchdog и запустить ОС.
Затем выполните apt update && apt upgrade.
Включите Watchdog и проверьте работу.
Если не поможет, то сделайте сброс с помощью USB накопителя актуальным FIT-файлом.
Вопрос решен.
Проблема была в не качественном блоке питания. После замены блока питания контроллер заработал.
Спасибо за обратную связь.
Рад что удалось разобраться.
Пожалуйста, сообщите подробнее — в чем заключалась проблема с БП, недостаточное напряжение, мощность или повышенные пульсации?
Каким образом выяснили проблему?
