WB-MSW - invalid crc + invalid packet size: 0
Добрый день, на шине 4е датчиков WB-MSW v.3 + 2а датчика WB-MSW v.4. все было ок, пока не обновил firmware до 4.30.0 для WB-MSW v.4, и до 4.29.11 для WB-MSW v.3. После чего по шине пошли ошибки, см. лог
|11-09-2023 10:48:38.182 [wb-mqtt-serial]|WARNING: [modbus] failed to read 12 coil(s) @ 0 of device modbus:117: Serial protocol error: malformed response: invalid crc|
|11-09-2023 10:48:38.164 [wb-mqtt-serial]|WARNING: [serial client] Reading events failed: Serial protocol error: malformed response: invalid crc|
|11-09-2023 10:48:38.136 [wb-mqtt-serial]|WARNING: [serial client] Reading events failed: Serial protocol error: malformed response: invalid packet size: 0|
|11-09-2023 10:48:38.086 [wb-mqtt-serial]|WARNING: [serial client] Reading events failed: Serial protocol error: malformed response: invalid crc|
|11-09-2023 10:48:37.955 [wb-mqtt-serial]|WARNING: [modbus] failed to read 3 input(s) @ 106 of device modbus:117: Serial protocol error: malformed response: invalid crc|
|11-09-2023 10:48:37.937 [wb-mqtt-serial]|WARNING: [serial client] Reading events failed: Serial protocol error: malformed response: invalid crc|
|11-09-2023 10:48:37.907 [wb-mqtt-serial]|WARNING: [serial client] Reading events failed: Serial protocol error: malformed response: invalid packet size: 0|
|11-09-2023 10:48:37.859 [wb-mqtt-serial]|WARNING: [serial client] Reading events failed: Serial protocol error: malformed response: invalid crc|
|11-09-2023 10:48:37.510 [wb-mqtt-serial]|WARNING: [serial client] Reading events failed: Serial protocol error: malformed response: invalid packet size: 0|
|11-09-2023 10:48:37.461 [wb-mqtt-serial]|WARNING: [serial client] Reading events failed: Serial protocol error: malformed response: invalid crc|
|11-09-2023 10:48:37.069 [wb-mqtt-serial]|WARNING: [serial client] Reading events failed: Serial protocol error: malformed response: invalid packet size: 0|
|11-09-2023 10:48:37.019 [wb-mqtt-serial]|WARNING: [serial client] Reading events failed: Serial protocol error: malformed response: invalid crc|
методом проб и ошибок нашел WB-MSW v.4 из-за которого это происходит. Не уверен на 100%, но вроде он ближайший к контроллеру. Снимаем его - все ок. Перставил его в другое место - все ОК. Установил на его места другого WB-MSW v.4 с прошивкой 4.30.0, - проблема воспроизводится. Уже начал грешить на шину, но поставил на “проблемное место” WB-MSW v.3 со старой прошивкой 4.22.0 - и все работает, ошибок нет.
Помогите с решением. Вариант откатить датчики на предыдущую версию - тоже вариант, только стабильные версии подскажите пожалуйста для 3 и 4 поколения датчиков
Заранее спасибо,
Андрей
Пришлите диагностический архив. А также серийные номера всех датчиков.
По данному описанию, я бы все-таки перепроверил физическое состояние шины.
Перепроверил линию, проблем не обнаружил. Зато выяснил, что из заказанных 7и датчиков глюки в любом месте шины от следующих 2х датчиков:
address 10, hw: 5.2B/9, fw: 4.30.0, 147235
address 11, hw: 5.2B/9, fw: 4.30.0, 147239
остальные 5ть работают без проблем на этой же линии в любом месте шины. Вот данные по рабочим:
address 168, hw: 5.2B/9, fw: 4.30.0, serial 146958
address 188, hw: 5.2B/9, fw: 4.30.0, serial 147001
address 203, hw: 5.2B/9, fw: 4.30.0, serial 147069
address 206, hw: 5.2B/9, fw: 4.30.0, serial 147081
address 215, hw: 5.2B/9, fw: 4.30.0, serial 147115
оставив на шине только два датчика WB-MSW v.4 10 и 11 все работает нормально. Методом научного перебора обнаружил, что ошибки валятся если на шине есть датчик протечки
WBMWAC	4264631033	118	1.20.1
и один из WB-MSW v.4 с номерами 10 или 11.
Собрал все обратно, без WBMWAC 118 на шине, но с WB-MSW v.4 10 или 11 - ошибок нет
Подскажите куда копать, что прислать!?
Заранее огромное спасибо
P.S. данная линия уже больше года работает без каких-либо проблем (от слова совсем) пока не появились WB-MSW v.4 10 или 11
К сожалению, в первом сообщении я не запросил диагностический архив.
Создайте его при подключенных всех устройствах и пришлите его.
Приложил три архива:
all_diag - подключены все модули
without_WBMWAC - без модуля протечки, но с датчиками WB-MSW-10-11
without_WB-MSW-10-11 - без двух датчиков, но с модулем протечки
Огромное спасибо
(187.9 KB)
(188.0 KB)
(187.8 KB)
Вы можете убрать параметр “Читать не чаще” (read_rate_limit_ms) для данного порта? Вы его с какой целью устанавливали? Попробуйте без него и сообщите результат.
Через WebUI я убрать это значение не могу, только выставить в 0. Выставил, сохранил - не помогло, к сожалению. Лог прилагается. Почему на всех портах он выставлен, это хороший вопрос, похоже, что он был выставлен изначально так на контроллере
(187.0 KB)
Как убрать через веб-интерфейс: заходите в настройку порта, нажимаете на “Свойства” и убираете галочку с пункта “Читать не чаще”
В жизнь бы не догадался, думал, что это только в UI показывать или нет. Убрал на всех портах, не помогло к сожалению (
Спасибо
read_rate_limit_is_removed_diag_AEH7VGI_2023-09-14-11.35.33.zip (187.5 KB)
Странно конечно все.
Пока не вижу ничего явного, но давайте проверим в целом питание: какой блок питания установлен, напряжение на входе контроллера, что выдает Vout, а также какие устройства питаются от Vout, какие напрямую с БП.
Также я бы предложил (если по питанию все норм) в свойствах устройства установить галочку “Опрашивать устройство” и постепенно включать опрос устройств и смотреть появление ошибок. Просто искать проблему, когда устройства физически отключены, но есть в опросе, тяжеловато. Много лишнего. Давайте так попробуем локализовать, только вначале проверить питание.
тут как в зазеркалье, все страннее и страннее )) Откатил прошивку WBMWAC c 1.20.1 на 1.19.1
wb-mcu-fw-updater update-fw /dev/ttyRS485-1 -a118 --version 1.19.1  -f --debug
на шине подключено все, что ранее приводило к бесконечному флуду ошибками CRC. Прошло 10ть минут - флуда нет, эпизодически проскакивает
WARNING: [serial client] Failed to enable events for modbus:118: Serial protocol error: modbus exception, code 1
14-09-2023 12:13:08.668 [wb-mqtt-serial]	WARNING: [modbus] failed to read 7 coil(s) @ 5300 of device modbus:10: Serial protocol error: request timed out
14-09-2023 12:13:44.303 [wb-mqtt-serial]	WARNING: [modbus] failed to read 2 holding(s) @ 97 of device modbus:10: Serial protocol error: malformed response: invalid crc
“Лишние устройства” как-бы не лишние, а временно отключены )) но я сейчас максимально почищу конфигурацию, и пришлю лог еще раз
Подчистил в конфигурации все отключенные сейчас устройства, на шине включены WBMWAC 118 и все новые WB-MSW v.4 включая 10 и 11.
Флуда нет, лог приложил. Ради эксперимента могу обновить прошивку WBMWAC обратно на последнюю.
Жду дальнейших инструкций,
Спасибо
cleaned_diag_AEH7VGI_2023-09-14-12.33.26.zip (189.1 KB)
Да. Было б очень хорошо с обновленной прошивкой WBMWAC. Надо все-таки подтвердить или исключить влияние прошивки.
Ну и сосояние holding регистра 113 до и после обновления прошивки.
Посмотрите пожалуйста, это то что надо?
root@dr-wb:/mnt/data/diag# systemctl stop wb-mqtt-serial
root@dr-wb:/mnt/data/diag# modbus_client --debug -mrtu -b9600 -pnone -s2 /dev/ttyRS485-1 -a118 -t0x03 -r113
[76][03][00][71][00][01][DE][96]
Waiting for a confirmation...
<76><03><02><00><00><4C><4F>
SUCCESS: read 1 of elements:
	Data: 0x0000
Да. Гипотеза не подтвердилась…
Обновил прошивку на последнюю для WBMWAC 118 и понеслось. Смотрите ниже. Логи нужны?
wb-mcu-fw-updater update-fw /dev/ttyRS485-1 -a118  -f --debug
2023-09-14 13:53:29,264 Will run: fuser /dev/ttyRS485-1
2023-09-14 13:53:29,519 Clients of /dev/ttyRS485-1: 12059
2023-09-14 13:53:29,526 Will run: ps -o cmd= 12059
2023-09-14 13:53:29,728 Will run: fuser -k -STOP /dev/ttyRS485-1
2023-09-14 13:53:29,958 Reading /usr/lib/wb-release for releases info
2023-09-14 13:53:29,963 Got releases info:
2023-09-14 13:53:29,967 	defaultdict(<function parse_releases.<locals>.<lambda> at 0xa5ecf7c0>, {'RELEASE_NAME': 'wb-2307', 'SUITE': 'stable', 'TARGET': 'wb6/bullseye', 'REPO_PREFIX': ''})
2023-09-14 13:53:29,973 GET: http://fw-releases.wirenboard.com/
2023-09-14 13:53:40,327 Set {'baudrate': 9600, 'parity': 'N', 'stopbits': 2} to /dev/ttyRS485-1
2023-09-14 13:53:40,331 /dev/ttyRS485-1 response_timeout -> 0.20
2023-09-14 13:53:40,458 Set {'baudrate': 9600, 'parity': 'N', 'stopbits': 2} to /dev/ttyRS485-1
2023-09-14 13:53:40,462 /dev/ttyRS485-1 response_timeout -> 0.20
2023-09-14 13:53:40,467 Will find serial port settings for (/dev/ttyRS485-1 : 118; response_timeout: 0.20)...
2023-09-14 13:53:40,595 Has found serial port settings: {'baudrate': 9600, 'parity': 'N', 'stopbits': 2}
2023-09-14 13:53:40,940 /dev/ttyRS485-1 118:
2023-09-14 13:53:41,315 	WBMWAC 4264631033 wbmwacG 1.19.1 6447
2023-09-14 13:53:41,449 Removing device: {'slaveid': 118, 'port': '/dev/ttyRS485-1', 'fw_signature': 'wbmwacG'}
2023-09-14 13:53:41,574 FW releases files: ['http://fw-releases.wirenboard.com/fw/by-signature/release-versions.yaml']
2023-09-14 13:53:41,584 Looking to http://fw-releases.wirenboard.com/fw/by-signature/release-versions.yaml (suite: stable)
2023-09-14 13:53:41,591 GET: http://fw-releases.wirenboard.com/fw/by-signature/release-versions.yaml
2023-09-14 13:53:53,758 FW version for wbmwacG on release stable: 1.20.1 (endpoint: fw/by-signature/wbmwacG/main/1.20.1.wbfw)
2023-09-14 13:53:53,764 GET: http://fw-releases.wirenboard.com/fw/by-signature/wbmwacG/main/1.20.1.wbfw
2023-09-14 13:54:04,277 Trying to get fname from content-disposition
2023-09-14 13:54:04,290 Got fname: wbmwacG__1.20.1_master_919a7dc.wbfw
2023-09-14 13:54:04,295 http://fw-releases.wirenboard.com/fw/by-signature/wbmwacG/main/1.20.1.wbfw => /var/lib/wb-mcu-fw-updater/wbmwacG__1.20.1_master_919a7dc.wbfw
2023-09-14 13:54:04,301 fw (wbmwacG 118 on /dev/ttyRS485-1):
2023-09-14 13:54:04,306 Update: 1.19.1 -> 1.20.1 (wbmwacG 118 /dev/ttyRS485-1)
2023-09-14 13:54:04,422 Flashing approved for "wbmwacG" (/dev/ttyRS485-1 : 118)
2023-09-14 13:54:05,356 f = read_u16(<wb_modbus.bindings.WBModbusDeviceBase object at 0xa673d970>, 128) not succeed (try 1/5)
2023-09-14 13:54:05,563 f = read_u16(<wb_modbus.bindings.WBModbusDeviceBase object at 0xa673d970>, 128) not succeed (try 2/5)
2023-09-14 13:54:05,780 f = read_u16(<wb_modbus.bindings.WBModbusDeviceBase object at 0xa673d970>, 128) not succeed (try 3/5)
2023-09-14 13:54:05,990 f = read_u16(<wb_modbus.bindings.WBModbusDeviceBase object at 0xa673d970>, 128) not succeed (try 4/5)
2023-09-14 13:54:06,247 f = read_u16(<wb_modbus.bindings.WBModbusDeviceBase object at 0xa673d970>, 128) not succeed (try 5/5)
2023-09-14 13:54:06,253 Set {'baudrate': 9600, 'parity': 'N', 'stopbits': 2} to /dev/ttyRS485-1
2023-09-14 13:54:06,260 /dev/ttyRS485-1 response_timeout -> 0.20
2023-09-14 13:54:06,264 /dev/ttyRS485-1 response_timeout -> 5.00
2023-09-14 13:54:09,201 Flashing /var/lib/wb-mcu-fw-updater/wbmwacG__1.20.1_master_919a7dc.wbfw
2023-09-14 13:54:09,206 /dev/ttyRS485-1 response_timeout -> 6.00
2023-09-14 13:54:09,425 /dev/ttyRS485-1 response_timeout -> 5.00
100%|#################################################################################################################################################################################################################################################|201/201
2023-09-14 13:55:01,506 Done
2023-09-14 13:55:01,520 Has saved db to /var/lib/wb-mcu-fw-updater/devices.jsondb
2023-09-14 13:55:01,525 Will run: fuser -k -CONT /dev/ttyRS485-1
	Data: 0x0000
root@dr-wb:/mnt/data/diag# systemctl start wb-mqtt-serial
Да. Диагностический пришлите. Попробую воспроизвести.
С Debug включенным для wb-mqtt-serial только лучше.
