WB7 2207 OpenTherm
Добрый день. ВБ7 Стоял софт 2204 обновился через apt до 2207 в ВБ установлен модуль опен терм в мод2 он был не виден в системе… решил установить с ресетом 2207 в итоге все стало еще хуже…
При попытке открыть конфиг файлы:
Не удалось загрузить настройки WebUI.: MQTT RPC request timed out MqttTimeoutError
root@wirenboard-AFRGLI4U:~# systemctl list-units --type=service
UNIT LOAD ACTIVE SUB DESCRIPTION
avahi-daemon.service loaded active running Avahi mDNS/DNS-SD Stack
bluetooth.service loaded active running Bluetooth service
cgmanager.service loaded active running Cgroup management daemon
cron.service loaded active running Regular background program processing daemon
dbus.service loaded active running D-Bus System Message Bus
dnsmasq.service loaded active running dnsmasq - A lightweight DHCP and caching DNS server
getty@tty1.service loaded active running Getty on tty1
hostapd.service loaded active running LSB: Advanced IEEE 802.11 management daemon
ifup@eth0.service loaded active exited ifup for eth0
ifup@eth1.service loaded active exited ifup for eth1
kmod-static-nodes.service loaded active exited Create list of required static device nodes for the current kernel
knxd.service loaded active running KNX Daemon
mosquitto.service loaded active running Mosquitto MQTT v3.1/v3.1.1 Broker
netplug.service loaded active running LSB: Brings up/down network automatically
networking.service loaded active exited Raise network interfaces
nginx.service loaded active running A high performance web server and a reverse proxy server
ntp.service loaded active running LSB: Start NTP daemon
rsyslog.service loaded active running System Logging Service
serial-getty@ttyS0.service loaded active running Serial Getty on ttyS0
ssh.service loaded active running OpenBSD Secure Shell server
systemd-fsck-root.service loaded active exited File System Check on Root Device
systemd-fsck@dev-mmcblk0p6.service loaded active exited File System Check on /dev/mmcblk0p6
● systemd-journald.service loaded failed failed Journal Service
systemd-logind.service loaded active running Login Service
systemd-modules-load.service loaded active exited Load Kernel Modules
systemd-random-seed.service loaded active exited Load/Save Random Seed
systemd-remount-fs.service loaded active exited Remount Root and Kernel File Systems
systemd-sysctl.service loaded active exited Apply Kernel Variables
● systemd-tmpfiles-setup-dev.service loaded failed failed Create Static Device Nodes in /dev
● systemd-tmpfiles-setup.service loaded failed failed Create Volatile Files and Directories
systemd-udev-trigger.service loaded active exited udev Coldplug all Devices
systemd-udevd.service loaded active running udev Kernel Device Manager
systemd-update-utmp.service loaded active exited Update UTMP about System Boot/Shutdown
systemd-user-sessions.service loaded active exited Permit User Sessions
user@0.service loaded active running User Manager for UID 0
watchdog.service loaded active running watchdog daemon
wb-configs-early.service loaded active exited prepare mounts and symlinks to config files
wb-configs.service loaded active running watch config files
wb-diag-collect.service loaded active running one-click diagnostic data collector for Wiren Board, generating archive with data
wb-gsm-rtc-restore.service loaded active exited Restore local date from Wiren Board GSM RTC
wb-hwconf-manager.service loaded active exited Initialize Wiren Board Device Tree overlays
wb-init.service loaded active exited Initialize Wiren Board on successful boot
wb-knxd-config.service loaded active exited KNXD Configurator for Wiren Board
wb-mqtt-adc.service loaded active running MQTT Driver for ADC
● wb-mqtt-confed.service loaded failed failed Wiren Board configuration editor backend
wb-mqtt-db.service loaded active running Wiren Board database logger
wb-mqtt-gpio.service loaded active running MQTT Driver for GPIO-controlled switches
wb-mqtt-knx.service loaded active running Wiren Board MQTT KNX bridge
wb-mqtt-logs.service loaded active running Wiren Board journald to MQTT gateway
wb-mqtt-mbgate.service loaded active running Wiren Board MQTT to Modbus TCP gateway
wb-mqtt-metrics.service loaded active running metrics sender.
wb-mqtt-opcua.service loaded active running Wiren Board MQTT to OPC UA gateway
wb-mqtt-w1.service loaded active running Kernel 1-Wire MQTT driver for WB-HomA
wb-prepare.service loaded active exited initialize filesystems at first boot
wb-repart.service loaded active exited prepare partitions at first boot
● wb-rules.service loaded failed failed MQTT Rule engine for Wiren Board
wb-systime-adjust.service loaded active exited Compensation of systime in PPM from value, stored in device-tree (with opposite sign)
wb-watch-update.service loaded active running Wiren Board firmware update service
Список сервисов вижу.
Но гораздо лучше - выложить диагностический архив. Ну и актуальный статус wb-mqtt-confed
Поставил систему с другого образа (fit) чуть старее но тож от сентября. Все завелось отлично :+1:t3: не смог найти этой темы чтоб закрыть.
