WBE2R-R-ZIGBEE v.2.2 Failed to connect to the adapter
Здравствуйте. Стабильно работал и сегодня сам собой отвалился zigbee модуль. Ревизия 2.2. Логи:
Starting Zigbee2MQTT without watchdog.
[2025-09-25 10:18:31] info: 	z2m: Logging to console, file (filename: log.log)
[2025-09-25 10:18:34] info: 	z2m: Starting Zigbee2MQTT version 2.5.1 (commit #unknown)
[2025-09-25 10:18:34] info: 	z2m: Starting zigbee-herdsman (4.3.1)
[2025-09-25 10:18:38] info: 	zh:zstack:znp: Opening SerialPort with {"path":"/dev/ttyMOD1","baudRate":115200,"rtscts":false,"autoOpen":false}
[2025-09-25 10:18:38] info: 	zh:zstack:znp: Serialport opened
[2025-09-25 10:18:38] info: 	zh:zstack:znp: Writing CC2530/CC2531 skip bootloader payload
[2025-09-25 10:18:40] info: 	zh:zstack:znp: Skip bootloader for CC2652/CC1352
[2025-09-25 10:18:58] error: 	z2m: Error while starting zigbee-herdsman
[2025-09-25 10:18:58] error: 	z2m: Failed to start zigbee-herdsman
[2025-09-25 10:18:58] error: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start_crashes-runtime.html for possible solutions
[2025-09-25 10:18:58] error: 	z2m: Exiting...
[2025-09-25 10:19:01] error: 	z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter.start (/mnt/data/root/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.3.1/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:114:27)
    at Controller.start (/mnt/data/root/zigbee2mqtt/node_modules/.pnpm/zigbee-herdsman@4.3.1/node_modules/zigbee-herdsman/src/controller/controller.ts:133:29)
    at Zigbee.start (/mnt/data/root/zigbee2mqtt/lib/zigbee.ts:68:27)
    at Controller.start (/mnt/data/root/zigbee2mqtt/lib/controller.ts:101:13)
    at start (/mnt/data/root/zigbee2mqtt/index.js:149:5)
ls -l /dev/ttyMOD*
lrwxrwxrwx 1 root root 7 Sep 25 09:55 /dev/ttyMOD1 -> ttymxc2
cat /etc/wb-hardware.conf
“mod1”: {
“module”: “wbe2r-r-zigbee”,
“options”: {}
“extio1”: {
“module”: “wbio-do-ssr-8”,
“options”: {}
И, кроме диагносического архива, попробуйте еще выключить контроллер, отключить питание и включить снова.
(206,8 КБ)
Конечно, первое, что я пробовал сделать.
Спасибо! Посмотрел: модуль неисправен, и гарантия на него закончилась – модуль приобретался в составе контроллера в 2020 году?
Предлагаю для окончательной диагностики переставить модуль в MOD3 (перенастроить zigbee2mqtt) и проверить. Когда модуль будете вынимать, сфотографируйте его, пожалуйста, с обеих сотрон.
Возможно еще попробовать перепрошить модуль, но прежде я хотел на него посмотреть.
Странно. Переставил в MOD3 - заработал. Спасибо!
у меня сейчас такая же ошибка была. я крышку контроллера отодрал, пальцем на модуль нажал и перезапустил… вроде заработало
