Батарея WBMZ6-BATTERY не заряжается. Температура в норме.
А какое напряжение на входе контроллера?
Покажите результат
for f in /sys/class/power_supply/wbec-battery/*; do [ -f "$f" ] && echo "$(basename $f): $(cat $f 2>/dev/null)"; done
ну и (для проверки) попробуйте немного остудить контроллер - снимите верхнюю крышку корпуса, например.
Также - обновите прошивку EC: Wiren Board Embedded Controller — Wiren Board
root@wirenboard-AYRX5NL:~# for f in /sys/class/power_supply/wbec-battery/*; do [ -f “$f” ] && echo “$(basename $f): $(cat $f 2>/dev/null)”; done
capacity: 58
charge_full_design: 2600000
constant_charge_current: 600
constant_charge_current_max: 600
current_now: 0
energy_full_design: 0
health: Good
online: 1
present: 1
status: Charging
temp: 429
type: Battery
uevent: OF_NAME=wbec-battery
OF_FULLNAME=/soc/spi@5011000/wbec@0/wbec-battery@0
OF_COMPATIBLE_0=wirenboard,wbec-battery
OF_COMPATIBLE_N=1
POWER_SUPPLY_NAME=wbec-battery
POWER_SUPPLY_TYPE=Battery
POWER_SUPPLY_PRESENT=1
POWER_SUPPLY_ONLINE=1
POWER_SUPPLY_STATUS=Charging
POWER_SUPPLY_VOLTAGE_NOW=3839000
POWER_SUPPLY_CURRENT_NOW=0
POWER_SUPPLY_CHARGE_FULL_DESIGN=2600000
POWER_SUPPLY_ENERGY_FULL_DESIGN=0
POWER_SUPPLY_CONSTANT_CHARGE_CURRENT=600
POWER_SUPPLY_CONSTANT_CHARGE_CURRENT_MAX=600
POWER_SUPPLY_HEALTH=Good
POWER_SUPPLY_VOLTAGE_MAX_DESIGN=4100000
POWER_SUPPLY_VOLTAGE_MIN_DESIGN=2900000
POWER_SUPPLY_CAPACITY=58
POWER_SUPPLY_TEMP=429
voltage_max_design: 4100000
voltage_min_design: 2900000
voltage_now: 3839000
Спасибо, обновление прошивки EC вроде помогло.
Ну отлично, рад.
